AVS › AVS Forum › Audio › Speakers › Upgrade of Klipsch Quintet system
post #1 of 5
I have had the Quintet setup with a Klipsch 450 sub for a few years now. Reciever is a Yamaha with 70 RMS. I have been wanting to start upgrading for a while and with Black Friday coming the Icon KF-26's will be once again on sale for 50% off.
Any recommendations on upgrading to the floorstanders now with my 70 watt receiver. I can get the 2 floorstanders for 175 each. I know the KF's are rated at 100W and I only have 70. I know the KF's are 6db more sensitive and I could turn the levels down on them at first.
Any thoughts on this upgrade path.
Current setup
Receiver Yamaha RX-V475
Speakers Klipsch Quintet
Sub Klipsch SW-450
post #2 of 5
I personally would go with a pair of the Klipsch RB-51 II, it will run you about the same price, but the Reference series is much better than the Icons. I recommend bookshelves instead of towers because when paired with a sub, the end result is essentially the same. Your receiver will set a crossover for your speakers, and since subs do a better job with bass, the benefit of towers (lower extension) is a moot point.
Klipsch speakers have good sensitivities, and your receiver will have more than enough power. I think going with the Reference series would be a more significant upgrade for you. Later on add the matching center and you can keep your current Quintets as surrounds for 5.1 or even 7.1.
post #3 of 5
I see setups with towers and the subs all day.. If towers were not needed then why would I see setups with 2 towers, center, LR surrounds and the sub? I understand your point but I guess this is where my inexperience comes in.
post #4 of 5
Some people prefer the look of towers. In some cases, mainly with budget speakers, the cost of stands sometimes is the difference between a bookshelf and tower, so people opt for the towers. I am sure peope think they sound much better, but a good sub and bookshelf system will perform just as well.
post #5 of 5
Crutchfield has the cherry RB61IIs for $399. Klipsch just also released to the US the new, old versions which include the RB-600 (RB61 version 1) for $399 a pair. Call AVS for their prices on Klipsch if you live in the continental US.
  Back to Forum: Speakers
