AVS › AVS Forum › Audio › CD Players & Dedicated Music Transports › No USB input on Bose Player
post #1 of 6
I have a Bose radio player with phono inputs to connect a cd player with phono outputs but it has no USB input. I have a USB flash drive stick with music on it that I would like to play on my Bose player. Is it possible and if it is, how can I do this? Does this require a USB type of player to be connected and what kind of adapters would I need?
post #2 of 6
I'm just guessing but I think you might have to copy the data out to CDR.
post #3 of 6
What is a CDR?
post #4 of 6
It means burning it to a disc.
post #5 of 6
What is a CDR?
CD-R (recordable CD) would have been more accurate. It is a CD to which you can record. Your computer is likely capable of handling it. It is a common thing to do.
post #6 of 6
You need a flash mp3 player (with those songs transferred into), connected to the line-in of the Bose. Since that Bose is not a high audio quality radio anyway, you will not loose anything.
For example: http://www.amazon.com/Silver-Metal-Clip-Player-supports/dp/B004S42RSW/
