AVS › AVS Forum › Video Components › Home Theater Computers › media player issues inside media browser
post #1 of 11
Having issues with playing media player inside media browser. I initially just had LAV and using MPC, but now with a ceton echo I need to get media player to work. I could get mkv files to play fine from outside media center, but once inside I get no audio and my receiver just said "stereo". I tried installing shark 007 again and same issue. Media player 32 bit and 64 bit play fine when I go into file explorer and tell them to play. Get inside media browser and no audio.
Anyone have any idea? I wish I could find all codecs installed and remove and start from scratch as I had it working once, but tried MPC as I couldn't get forced subtitles to work any other way than that and LAV.
post #2 of 11
What exactly is the question? Are you trying to get mkv playback on a ceton echo using MPC-HC?
post #3 of 11
If that is possible yes, but otherwise I need to figure out why media player won't play audio on host machine at the moment inside media browser. I haven't even checked what it is doing on the Echo as I figured not worth it if host is broke.
post #4 of 11
Take a look here and here.
The echo has limited mkv playback depending on the file and will play them once the codecs are properly installed on the host machine.
Edited by Sammy2 - 11/17/13 at 6:11pm
post #5 of 11
Anyone have any idea, taking echo out of conversation, why media player acts differently in my case out of media browser? Also, any tips on cleaning out all codecs to start from scratch? For some reason I have no old Windows restore points to revert to.
post #6 of 11
I'll take a stab at it. 1st of all, you need to know that Media Center does not use Windows Media Player for Video playback. Media Browser uses the Media Center player for playback. (unless you told it to do differently) You probably have a 64bit Operating System. Media Center is using 64bit codecs for playback whie the default WMP is using 32bit codecs for playback. So... you're trying to compare 2 different players from 2 different platforms. Tough to do.
As for cleaning codecs, I have several tools built into my codec releases that will assist you with that. My releases are focused on supporting usage of the Windows players.
EDIT, you really should look in Control Panel | Programs and Features,
and remove what you can find on your own to get started.
Edited by Shark007 - 11/17/13 at 5:58pm
post #7 of 11
I used Assassin's setup way back when to get it going and went back to it before posting here. One thing I noticed when running through the LAV setup under his "WMC & MB Setup" was that GraphStudio is showing audio coming through MPC - MPA Decoder Filter instead of LAV as shown (even after I un-installed Media Player Classic). Even after installing Shark007 I still have same issue.
EDIT: Okay, found that RemotePotato Streaming Pack was the MPC - MPA Decoder Filter, I've removed that remotely so I have no way to check if that solved all my problems. Will check tonight when I'm home
Also, I did have Media Browser working on the Echo before I went to use Media Player Classic to fix subtitle issue.
I guess I'm confused with the statement as to Media Center Player and Windows Media Player, doesn't your software have a check box to to tell which Windows Media Player to use, 32 or 64 bit?
I have flipped through my installed programs to uninstall and extraneous codecs and see nothing that stands out.
Lesson learned here is I should have left well enough alone with the subtitles.
Edited by lancer1991 - 11/18/13 at 9:47am
post #8 of 11
I'll explain further. On a 64bit Operating System (with Media Center) Microsoft Windows supplies three different players.
1. Windows Media Player - 32bit (only uses 32bit codecs)
2. Windows Media Player - 64bit (only uses 64bit codecs)
3. Media Center (player) 64bit <-- this player does not use Windows Media Player to playback video files.
Yes, my software can make the 64bit WMP the default player instead of the 32bit being the default as supplied by Microsoft.
In my experience, there is no advantage what-so-ever to setting the 64bit player as default.
I supply the option to set the default player solely at user request.
post #9 of 11
In your best guess, is it just dumb luck that the codecs weren't working for the audio for Media Center Player then if they took for Windows Media Player or that the codec from RemotePotato just interfered with only Media Center Player.
I appreciate the assistance, and hopefully I'll find all is working right tonight. Otherwise I may just blow away the install and start from scratch. Probably have a bunch of stuff installed that have been replaced or improved upon over the past few years I've been running this.
post #10 of 11
My best guess is to offer no guess at all. I have never used RemotePotato. Just now, I had a quick look at the RemotePotato download page and they do offer 64bit specific downloads therefore it is entirely possible that it caused the audio problem in Media Center.
A clean OS install is not always necessary but does assure that you'll cleanup your current situation. BUT, keep in mind, you may just place yourself right back to where you are now depending on what you choose to install.
post #11 of 11
Well removing the Remote Potato codec fixed Media Browser on host PC, but broke audio on watching videos on my phone or tablet via app. Tried clicking the extender options in Shark007 to get Echo to work. Was fine on DVD, but Blu-ray MKV didn't want to play well.
Will have to continue to tinker and ultimately at the end get forced subtitles to work again.
