AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › MX 150 Oppo 95 3D handshake problem
post #1 of 3
I have been having a problem with my MX 150 when playing 3D material with my Oppo 95. I have the Oppo HDMI 2 hooked into the MX 150 for sound and HDMI 1 directly feeding the display. I switch between a projector and a large LED display. In all cases the sound cuts in and out randomly. I have found no combination of settings that seem to work and I have used various cables. As a test I bought a Sony BDP S790 with dual HDMI outs and it seems to work fine, however I am not convinced it is really the Oppo. Does anyone have any knowledge of this type of problem. Much Appreciated.
post #2 of 3
I think oppo doesnt like Mx150
In my case i cant let my mx 150 and my oppo 95 on without a disc inside !
In that case there is a very loud bad sound coming out from my 7 speakers!
post #3 of 3
The oppo 95 does have occasional issues with different oem vendor's implementation of the momentum data systems board. The rs 20i at Prometheus had some issues. Other vendors too.
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
