AVS › AVS Forum › Audio › Speakers › Speaker/Receiver Assistance Needed
post #1 of 7
So I am looking to buy into a 5.1 system which includes Klipsch speakers (personal taste) and the Rythmik Audio LV12R sub.
Looking in particular at these Klipsch models:
RC-52 II Center
RB-61 II Bookshelves (Floor standing will not work in my setup due to in wall shelving which will put the tweeter way above ear level)
RS-42 II Surrounds or RS-52 II
I have yet to be set on a receiver although Denon/Onkyo would be preferred.
Room size: 17' 9" x 13' x 8'
Budget: $2,000 (excluding the sub money already set aside)
Looking to find a premium receiver and best deal on these speakers.
Already have leads with acousticsounddesign.com ($1,497 on these speakers) and AV Science ($1,416 on these speakers).
Room diagram:
Edited by 513HTGuy - 11/21/13 at 9:34pm
post #2 of 7
Post pictures of your entertainment center.
post #3 of 7
post #4 of 7
AV Science is probably going to give you the best deal. Contact them about a receiver as well, something like a Denon AVR-X1000 would work well. It has Audyssey MultEQ XT and networking, however if you plan on going with 4K at some point in the near future, I would upgrade to the X2000. I don't think 7.1 is an option in your room so no need to go with a 7.1 receiver unless you want to power a second zone at some point. Klipsch speakers have good sensitivity so just about any receiver will drive them louder than you care to listen, making pre-outs not necessary.
post #5 of 7
I will contact AV Science today. Had jdsmoothie from AV Science respond to my thread in the receiver section.  Bond also mentioned the Denon AVR-X2000. I don't really plan on a Zone 2 down the road.
post #6 of 7
You are likely to get a better deal on everything if you buy it all together, and they are also an authorized SVS dealer, so you may be able to get a good deal on a SVS PB12-NSD wink.gif
post #7 of 7
Ha, just had a discussion yesterday about the sub and settled for the Rythmik LV12R over the SVS PB-1000. Unless it is a really good deal I wouldn't consider it after reading up on the LV12R from Jim's review and around the forums.
  Back to Forum: Speakers
