AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Samsung PS51E557 calibration problem.
post #1 of 7
Hi...I have some calibration problem on my TV...Changes of brightness and Cell light have no result on bright picture. Also I have very agressive Auto Bright Limmiter(ABL), and its too stroby on ice hockey....
http://motkarast.ucoz.ru/bright.gif
http://motkarast.ucoz.ru/cell.gif
http://motkarast.ucoz.ru/bad1.gif
Can I change something in Service menu(may be in advanced, panel type or else) to calibrate ABL? Is it warianty case? Any suggestions?
Thank You....
post #2 of 7
ABL is not configurable
post #3 of 7
can I turn of it from advanced service menu? Is my videos  normal?
Edited by Motka - 11/22/13 at 11:58pm
post #4 of 7
My problem is something like that
http://www.youtube.com/watch?v=E3_xN2xs2vA
Any idea?
post #5 of 7
You're looking at ABL which is normal and can't be turned off. If I remember correctly it's less agressive if you set cell light to maximum. Also, in your first post you're moving the brightness control which affects black level, not light output. Use the contrast control for that.
post #6 of 7
That pops increses when contrast is lower than 70, but picture is awfull. Cell light can't change anythig.
post #7 of 7
I did not look at video.On samsung 51pne450 here I don't notice popping with hockey unless I'm really looking for it and sitting close.I did notice it a bit when I first got it,but it was not bad enough too return it.Maybe it's worse when tv is new,as plasmas take a while too settle..::...Some have tried different firmwares,but you risk having other problems if you do it.Maybe try different settings...If it's really noticeable,then return it.
