AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Trying to understand sound modes. Denon AVR X2000
post #1 of 5
I have center, and two front channels, full range speakers. No sub yet.
Rear and center rear, small speakers.
6 speakers in all. A 6.1 system without the '1'
I'm trying to understand when to use a given sound mode.
For example...the Walking Dead on DirecTV..do I need to know what it was broadcast in? Or do I simply chose the mode that sound best to my ears?
And if so do I do this for every TV show? Or is there a recommendation?
Thanks for any tips.
post #2 of 5
You can choose to listen to audio in the format in which it's recorded or broadcast (stereo, 5.1, 7.1, etc.) or you can choose to change / enhance it as you like (using modes such as PLIIX, NEO:6, etc.).
Example: If you're listening to something broadcast in stereo and you find that it sounds better "matrixed" into multi-channel audio, enjoy it in multi-channel audio.
post #3 of 5
Thanks but how do I listen in the mode it was made in.
Will the receiver automatically 'know'.
post #4 of 5
In the Source set up menu; keep the Decode Mode to Auto. I think that is the default value. Your avr will default to the native format recorded on the source.
post #5 of 5
For more helpful information on your new Denon X2000, please join us in the Denon E/X Series Owner's thread linked below, reviewing posts #3-6 in that thread first.
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#post_23134210
