AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › Xbox Area › Recommendation for OTA antenna with HDMI out for XBONE?
post #1 of 7
Hi everyone
like many here I just got the XBONE yesterday. Loving it so far, but one of the reasons I purchased it was to try the live TV control through HDMI and I realize I may not have the correct hardware.
First off, I only use OTA TV, not cable. Currently I have a regular antenna which obviously I can't plug into my XBOX. I was thinking of trying to use an HD Homerun I have (using the Ethernet port or something) but apparently it's not supported either.
Finally, I could route everything through my HTPC using WMC but the XBOX can't control my HTPC that well (XBMC etc) so I'd rather keep both on separate HDMI inputs.
So what I really need is an HDTV antenna with an HDMI output so that I can plug it into my XBOX and get a tv signal.
Can someone recommend one?
post #2 of 7
Your going to need one more thing, a HDTV receiver/tuner with HDMI output. You plug the antenna into the receiver/tuner and the receiver/tuner into the XBone HDMI input.
post #3 of 7
post #4 of 7
You would want to get one that you are sure is supported by the XBone so that the IR codes work. You are looking for something like this but like I said, it's important do set what MS supports with IR codes. I haven't seen that list anywhere yet.
http://www.amazon.com/iView-3500STB-DTV-Converter-Box/dp/B00BFIJQ10/ref=pd_rhf_gw_p_t_2_0KJW#productDetails
They are talking about them in this thread:
http://www.avsforum.com/t/1300997/any-recommendations-for-a-cheapish-ota-hd-tuner-with-hdmi-out
post #5 of 7
Thanks a bunch
post #6 of 7
FWIW: Someone in the XBone forum's are saying that the IR codes are in XBone for this one and it's working with voice command:
http://www.amazon.com/HomeWorx-HW-150PVR-Converter-Recording-Function/dp/B00CXAE92K
post #7 of 7
Thanks. Just ordered one no amazon. Will try it and report back here for those who are in my situation.
  Back to Forum: Xbox Area
