AVS › AVS Forum › Display Devices › CRT Projectors › cant get video-in signal to work on my nec 6pg
post #1 of 6
hello
i have worked out a quiet allright picture on my 6pg running through rgb to vga.
But if i connenct my playstation (1;) to the nec using a bnc to cinch kable absolutly nothing happens at all. i tried to create a new video imput channel but that didnt help it. i dont get it, am i doing something wrong here (again;) or is my video in may mest up. aja, and i did switch from s-video to video..
any thoughts?
thanks and
bw christoph
post #2 of 6
bw christoph
what's a Cinch cable? please use these terms
http://www.curtpalme.com/CRTPrimer_17.shtm
post #3 of 6
öhhh, a composite video cable to bnc (did it myself such as middlestring to middlestring and outer to outer..guess thats right..)
bw christoph
post #4 of 6
bw christoph
where did you plug the composite cable into, the 6PG does not come standard with the composite/S-video board?
The 9 Pg series in each model usually came stock with the point convergence board and the video/S-video board. The 6 series did not come with those boards, which can cause confusion when a new owner of a set finds the video and S-video inoperative even though the input selection will show in the menus.
post #5 of 6
ohh, thats bad. you mean even if i have a bnc video and s-video input, it doesnt mean they work? please, what do i need for (and wtf someone build a videoprojektor without a video-in,,!)
bw christoph
post #6 of 6
why would you want to watch composite video at 8 feet wide though (or at any size). I think you would be shocked at how horrible it will look. Find an old Fury 1 HDMI to RGBHV converter, they usually sell for 50 bucks although are still very popular and sell quckly. (the new Fury 3 is $300.+) Then you can watch 720P instead of 480 i;)
  Back to Forum: CRT Projectors
