AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Is the ae8000 much better than w1070?
post #1 of 5
I have the benq but I feel like I could get better?
Is the 8000 much better?
Is it brighter?
Clearer?
post #2 of 5
Would love hear from someone who had the 1070 who upgraded to the epson 5030 or ae8000 or anything under 3k
post #3 of 5
I had the W1070. The only projector I have seen that made me not miss dlp was the Sony HW50ES especially with. Reality creation
post #4 of 5
WHat is it about DLP that people like so much?
How come around 2500 there isnt anything dlp?
post #5 of 5
There is nothing around $2,500 DLP for no obvious reason at all. There should really be a DLP model which DOES compete with the Epson and Panasonic at that price range with motorized zoom, excellent lens shift, long zoom, and active iris. Unfortunately, DLP manufacturers just go cheap, cheap, cheap.
They can do this because the DLP technology itself is inherently better than LCD. It has, by far, the fastest response rate for any front projection technology with no real blurring or image degradation introduced by the chip set. The use of a single DLP chip means that you get a razor sharp image with cheaper optics which is a real plus for the consumer.
But of the 200+ 1080p projectors out there it's shocking that only 6 come in between $2,000 and $3,000 with the 2+ year old BenQ W7000 as the only reviewed model from Projector Central...
http://www.projectorcentral.com/projectors.cfm?g=1&hide=0&st=1&mfg=&p=2000&p=3000&w=&r=13&br=&ll=&ltg=&t=&db=&dt=3.0.0&c=&ar=&dvi=&wr=&pjl=&pjw=&pjh=&td=&i=d&is=&sort=pop&sz=15
I'm not sure if BenQ will follow up with a seriously improved W7000 or if they will just stick with that model for a couple of more years, but it is starting to get long in the tooth.
Instead, an upgraded version with more shift, zoom range, etc. would all be ideal and an excellent competitor to the LCD products that are similarly priced.
Still, if I had $2,500 I would figure out how to get to $3,000 so I could get the JVC RS46 or one of the Sony LCoS models.
