AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Epson 3010 blue glow in lower right corner
post #1 of 5
I have an Epson 3010 projector - it's been great so far! A couple months ago, I noticed that when I start it up there's a blue glow in the lower right hand corner. After a few minutes (no more than 5 or so), the glow dissipates. Does anyone know what is causing this and how to fix it? I've had it for almost 3 years so it's out of warranty.
IMG_20130808_204647.jpg 69k .jpg file
IMG_20130808_204658.jpg 71k .jpg file
IMG_20130808_204714.jpg 75k .jpg file
post #2 of 5
I've got the exact same thing on my Epson 3010 in the lower right corner when I power on the projector, and it goes away after a few minutes.
I've had the projector since 11/2011 and it's got just over 1400 hours on it.
post #3 of 5
+1. I have the same issue. I noticed it about a month ago. Since it goes away after some time, didn't pay much attention to it.
post #4 of 5
Glad to see that I'm not the only one with the issue. I just emailed Epson support about this issue, I'll see what they come back with response wise and update here.
post #5 of 5
This is the response I got from Epson:
It is not uncommon to see discoloration in the image when the projector is warming up. The most common is a greenish hue that can appear when the projector first powers up and goes away after the unit has warmed up. What you are describing would have more to do with the optical engine and not the lamp. The lamp is only the light source and is primarily responsible for brightness. It does not produce actual colors or images.
Richard M.
