AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Need help finding a new Plasma!
post #1 of 2
Help!
I was sent to here to get some help finding a new tv. I want to go plasma, and my primary use is with a ps4, so low input lag would be nice. The problem is that I, of course, have a budget. The tv cannot be bigger than 50 inches, so ideally it will be 46-50 inches. I really wouldn't like to spend more than 600.
My current tv is a 32 inch vizio.
I appreciate all of your help!
post #2 of 2
Get the Panasonic 50S60. It's by far the best TV in that price range and has the lowest input lag of all plasma TVs. It runs about $650-700
