AVS › AVS Forum › HDTV › HDTV Technical › Collinsville, OK: Large directional with pre-amp antenna question
post #1 of 10
I have performed an TV fool analysis but I am not sure how to decipher the results (link below). I have also performed an AntennaWeb analysis which says I need a large-directional with pre-amp but I am not sure which one and I have read that it is better to get one without pre-amp first so I do not over drive anything that is close.
Can someone recommend an antenna to get my search started? Do I really need to get the biggest/baddest or is that overkill?
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d46ae8f45f30251
Thank you,
David
post #2 of 10
It's going to depend on how many TVs you're driving and how long the coax is. Given your distance, I doubt that'd be an issue. I'd go with the large UHF/VHF-Hi combo pointed at Coweta. If you get signal issues, then you might consider shimmying up the pole and adding a pre-amp. I'm 10-15 miles from the Detroit transmitters and I have a 30db Blonder-Tongue pre-amp connected to my array (35-element UHF yagi and a separate VHF-Hi) feeding 6 tuners and it doesn't overload anything. No, I didn't need that much, but the primary purpose of the thing is pulling in signals from Toledo, Lansing and Flint.
But I digress.KOED, KTUL and KJRH transmit on VHF. Everyone else you'd probably care about is on UHF all coming from Coweta.
post #3 of 10
So would this be something that would be best served by separate VHF and UHF antenna? I am hoping to be able to place them in the attic.
We will be driving 2 TVs with a maximum run of about 125'.
I am thinking something along the lines of http://www.amazon.com/Winegard-HD7694P-High-Definition-Antenna/dp/B001DFTGR4/ref=sr_1_13?ie=UTF8&qid=1385524897&sr=8-13&keywords=uhf+yagi
This would be for single unit.
If separate I am thinking:
UHF - http://www.amazon.com/Antennas-Direct-91XG-Uni-Directional-Antenna/dp/B000LZ9EXI/ref=sr_1_2?ie=UTF8&qid=1385525658&sr=8-2&keywords=Antennas+Direct+C5 or http://www.amazon.com/Antennas-Direct-ClearStream4-HDTV-Antenna/dp/B001BRXW74/ref=sr_1_1?ie=UTF8&qid=1385525848&sr=8-1&keywords=clearstream+4
VHF - I cannot seem to locate a specific one for this. Any recommendations?
I really appreciate the help.
Edited by David Borg - 11/26/13 at 8:22pm
post #4 of 10
Something like this, http://www.solidsignal.com/pview.asp?p=y5-7-13&d=antennacraft-by-radioshack-y5-7-13-highband-broadband-vhf-yagi-tv-antenna-for-channels-7-13-(y5-7-13)&sku=716079000987 would be good for your channels 8 and 10. The antennas direct C5 would be more compact if space is an issue but I find it to be rather highly priced for what it is.
post #5 of 10
Thank you for the recommendation. Size is not an issue so that should work well. I am assuming that I need something to combine the signals from both antennas. What should I look for?
post #6 of 10
No, no no. You don't NEED two antennas. the combo you first linked to should do okay, but don't be afraid to add the pre-amp. I was just illustrating the fact that adding a pre-amp doesn't automatically result on "overdriving." Even so, it's a lot easier to put an attenuator in the line behind the tuner. You can remove it later far easier than go out in the winter and add a pre-amp.
post #7 of 10
Got it. Thank you for the clarification.
I must say the suggestions and info is helpful.
Have a happy Thanksgiving all.
post #8 of 10
One last question.......
I am going to go with the single antenna and add the pre-amp. With that said, I am going to be splitting it to 3 rooms (decided to add 3rd tv). The run from the pre-amp to the power unit for it will be about 20 feet and the run from the power unit to the splitter will be 5-10'. The run from the splitter to each room will vary from 50'-100'.
My question is....do I need to get a power distribution/powered splitter or would a passive 4-way splitter be sufficient? I am getting a little confused on all of the dB losses and such.
post #9 of 10
Start with passive and see how it goes. Given your distance and the relative lack of significant topography between you and Coweta, it should be plenty, storms notwithstanding.
post #10 of 10
Basically every time you split a signal you 1/2 the power which is equivalent to 3.0dB of loss...not much different than having a pipe of water being split, essentially 1/2 the amount of water pressure out of each split. Like the above poster recommended, I would start with a passive splitter (cheaper cost wise) and if the signals are not strong enough at the TV's then look at getting a decent amplifier. If you do go that route, personally I recommend the Channel Master amps.
  Back to Forum: HDTV Technical
