AVS › AVS Forum › Display Devices › Rear Projection Units › Mitsubishi WD-73C9 DLP HDMI Problem
post #1 of 4
I have a WD-73C9 TV, when I run my HDMI video from the cable box -> Xbox One -> Receiver -> TV I get no video. Below are some of the things I have tried:
  • Switched HDMI Cables
  • Replaced the Receiver to a Denon AVR-3000
  • Upgraded the TVs firmware
  • Reset the TV using Menu 123 per the Mitsubishi site
If I take the same exact cable going to the HDMI port on the back of the TV as going into the receiver it works.  I had this exact same problem with an Onkyo SR806 and after fooling around had thought it to be the receiver and therefore bought the new one.  Sadly, I'm now $600 lighter in the pocket and have the same problem.
Anyone have any suggestions, I'm at my wits end.
Edited by Adydar - 11/27/13 at 6:03pm
post #2 of 4
Turn off CEC if on and turn off all video processing on the receiver.
post #3 of 4
Thanks for the suggestions, CEC is off already.  Is there a way to disable the video processing from the receiver itself?  I'm unable to get video display from it to see the menus.  Been googling but haven't found anything yet
post #4 of 4
I ordered a mainboard for the TV from eBay, we'll see if that does the trick.  I'm still open to suggestions should anyone have any more thoughts.
  Back to Forum: Rear Projection Units
