AVS › AVS Forum › Display Devices › Screens › Vivid Screens??
Vivid Screens??
post #1 of 2
Has anyone used this screen before? I did a search and came up empty. I have a Mitsubishi HC7900-DW projector and I'm looking for an inexpensive screen to use now and then upgrade later when I can. Thanks!
http://www.a1components.com/Products/Vivid-92-in-Matte-White-Projection-Screen-with-Black-Velvet-Frame--HDTV-(16-9)__VFS392FS.aspx
post #2 of 2
If you're looking for an inexpensive screen for now look at an elite screen. They are pretty well known and people tend to be happy with them. They are also less expensive than the one you listed.
http://www.amazon.com/Elite-Screens-ER92WH1-Projection-Screen/dp/B00366MBAC/ref=sr_1_2?ie=UTF8&qid=1385651473&sr=8-2&keywords=Elite+fixed+frame
  Back to Forum: Screens
