AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic st-60 disappointingly dim
post #1 of 17
Just picked up a Panasonic st-60 yesterday. I have a rather dark lit viewing area and figured that a plasma display wouldn't be affected by the ambient light. The documentation and reviews regarding this issue seem to support this assumption. After setting up the tv, I am rather disappointed that the display is so dim. Whites are light grey. I have attempted to adjust settings... The color levels are appropriate, the issue is simply a lack of light output. The dark spectrum is amazing, and the contrast is great, but it seems the television is greatly lacking fl output. I am wondering if there is an optimal setting to maximize light output. I read to put it on "vivid" (dynamic) viewing mode, but this is even dimmer than cinema or standard. I have turned off the C.A.T.S. Auto dimming feature. Any suggestions? Thanks ahead of time!
Tyler
post #2 of 17
Tyler forget about standard that is a worthless mode designed so that the set can meet energy star guidelines. There is a second setting in the eco saver menu make sure that is set to "standard". Either the cinema mode or custom mode in the mid 80's should give you plenty of light output. A contrast of 82 in custom gives me 42ftl which is more than sufficient for my moderately lit room.
post #3 of 17
If you're coming from an LED, give it some time (after you've done as Chunon suggested).
post #4 of 17
Anyone care to point us to the right direction or share all their settings for a bright room?
It doesn't have to be very color accurate. I'm very happy with my st60 purchase, it's just that sometimes I'd like to leave my windows open. Basically, I'm planning on having two settings. One color critical at custom/cinema and the other brightroom at home theater perhaps?
For now, I'll try to play around with Chunon's recommendation.
post #5 of 17
Another thing to double check in either pro or advanced settings (I forget) is that you have black level set to light NOT dark.
post #6 of 17
Tyler
Thats very odd. Dynamic mode should've blinded you
post #7 of 17
Is there a calibration for vivid picture mode? The rest of the modes seem extremely dim. I like vivid but the colors seem to be off somehow.
post #8 of 17
I'd give these settings a shot first and then go from there:
http://www.controlcal.com/forum/showpost.php?p=6914&postcount=2
I've seen it said that over time the panels will get a bit brighter. I don't know how much merit that holds, but to me it looks like my panel (60VT60) is a bit brighter now than the first week I spent with it.
Edited by absurd_username - 12/4/13 at 8:31am
post #9 of 17
I just received my 55st60 yesterday as well. I've read for about the first 100 hours (1 month or so) you actually want a dimmer than usual setting, with mostly full screen content to help age the phosphors and prevent burn in.
Sent from my iDevice using Tapatalk. Please excuse typos or brevity.
post #10 of 17
Coming from the ST50, I can say the ST50 is much brighter and the whites on the ST50 were much better. I got rid of the ST50 because of the yellow glob issues.
post #11 of 17
So you're saying you're ST50 was brighter than the ST60? Interesting.
post #12 of 17
Changing ECO saver to standard seems to do the trick. That definitely help with the panel brightness. The ST60 has a lot more sub menus and options over the ST50. Now it's as bright as my ST50 and now I have to bring the contrast down at bit using D-nice settings. When I had eco mode set to saving I didn't notice much image retention, will have to see what kind of IR I will get it with it set to standard.
Edited by jp0213x - 12/5/13 at 2:33pm
post #13 of 17
Well,
I must be crazy then.
Today I played with the settings on a 55" and 50" st60 in the store for almost an hour, did all the above, and seriously, still looks dim to me. Certainly dimmer than my ST30. The only noticeable difference was the standard mode. Really dim, as usual.
Contrast on both sets were cranked up [ by the store] to 100% on all settings. Each set had about 3K hours on them.
Was disappointing, to say the least.
The S60 was even worse.
I know the color is stunning, but doesn't anyone else notice how dim the whites are?
post #14 of 17
Originally Posted by tvaddicted View Post
Well,
Making those kind of judgements in a store is not a good way to evaluate a set. I had the ST30 and the ST60 leaves it in the dust in contrast ratio light output and purity of whites.
post #15 of 17
I agree. The peak brightness measurements on both the S and ST 2013 models are higher then the 2011 and 2012 sets. The ST is the brightest of them all. If you are going to compare these TV's to most LCD's in a bright environment, like a big box store, you will be disappointed. Under controlled lighting conditions, none of these sets are too dim by most standards, however if your viewing habits require a brighter picture, look else ware.
Ian
post #16 of 17
Well,
Did you try all modes and make changes beyond contrast and brightness? What was gamma set at?
When judging whites do you look for the whitest thing on the image or the largest? I try to see if there's something whiter than the white I'm thinking isn't correct. A full white screen, sadly, isn't as white as it probably should be, ie the end of apple commercials, but that's just the abl doing it's thing. I'd rather suffer that then the problems other tvs, past and present, have.
post #17 of 17
i agree with chunon, how can you possibly judge a tv hanging up on a wall in the store? The ST60 we played around with in Sears was pretty crappy. Instead we researched and read reviews to decide our purchase.
We are completely happy that we bought this set. It is plenty bright in our living room with two wall lights and a ceiling fan with three more bulbs(total of 7 lights) and the most we do is to dim them, we never watch in a dark room. Too bright of a picture burns my eyes (I wear contacts).
In fact I have the contrast set just under 50 and the screen is fine for the both of us. Of course I realize everyone has their own preferences wink.gif
