AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › hd131xe not 1080p 60hz?
post #1 of 6
upgrading from my hd1000u, what a great projector, and I have a few questions
is the 131xe a bright projector, brighter than my hd1000u? I am projecting a 137 inch diagonal 16:9 screen
I was going between it and the w1070 but I have an 18 foot throw distance so I do not believe it will work for me.
I saw on projector central that the w1070 does 1080p 60hz but the 131xe only does 1080p 24hz is this an issue? Is there other projectors I should be looking at?
Use is mostly movies and TV (some sports) but I want it to work great for games on the consoles too. I will be using my PS3 for blu ray playback will upgrade to a ps4 when it has some games I want to play.
I want to stay DLP btw
post #2 of 6
Absolutely FALSE. This projector does 1080p 60hz as I use it with my HTPC and my Playstation 3 at 60hz all the damn time. LOL.
post #3 of 6
excellent, I was hoping it was a mistake, but I couldn't find anything to dispute it.
for my screen size and throw should I be considering the 25lv or just stick with the 131 xe and save the $300. I am guessing the 131xe will be way brighter than my hd1000u? I use a light controlled room but screwed up and painted my ceiling and doors white, walls are cherry color.
post #4 of 6
Looking at Projector Central's Calculator @ http://www.projectorcentral.com/Mitsubishi-HD1000U-projection-calculator-pro.htm
The HD1000u puts out a 13fL picture on a 137" screen at 18 ft...
And, actually neither the HD131Xe nor the HD25-LV can project a 137" screen at 18ft... they can only do that at 14'11" - 17' 11".
I suppose 17'11 is close enough to 18', though? I don't know. However, the HD131Xe at 17'11 projecting to 137" gives you about 18fL, which is a pretty big difference between 13fL from the HD1000u.
The HD25-LV gives you 23fL at that distance.
Both the HD131Xe and the HD25-LV will also be on minimum zoom when projecting the 137" image at that distance...
post #5 of 6
Just an FYI, if you ever want the details of any projector, look at the User Manual.
http://www.optomausa.com/webresources/files/support/2265_HD131Xe_UM.pdf
Page 60 lists over 30 accepted HDMI formats, including 1080p/60.
Of course, 3D at 1080p 60 is not a standard 3D format at this time and isn't accepted, but that's not what you asked about.
post #6 of 6
its 17'7 to the lens of the projector, so I am in range, barely...
I had not noticed the fL rating on the calculator thanks! I will try the 131xe and save the $300+. the hd1000u brightness was adequate but had that extra pop with a new bulb and I always run it on high, I have used only 2 bulbs, they have been used way past their suggested hours.
Thanks for the help, I hope to see a decent upgrade, though I have always been very happy with the hd1000u
