AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Which AV Reciever?
Which AV Reciever?
post #1 of 2
Hello,
Looking for an AV Rec with all the 'over the air' features Built-In (Wi-Fi, Air Play, Bluetooth, etc., etc.,- no dongles), Sonys are the only ones that I can find with all those features, but prefer either a Denon, Onkyo, or Yamaha. Any suggestions on models would be appreciated.
Thank you,
The Pilot:confused:
Edited by ThePilot - 12/8/13 at 9:07am
post #2 of 2
The Harman-Kardon AVR1700 has AirPlay and many other features and is under $300 at Amazon now.
That would be my recommendation.
IMO the reliability and sound quality of Harman-Kardon receivers is better than most of the others (especially Sony and Yamaha).
Amazon has a full detailed description of all its features if you look it up and scroll way down. It has AirPlay, USB input, network connectivity, etc. etc.
Edited by commsysman - 12/7/13 at 6:16am
