AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Comparing Pioneer SC-1328-K to VSX-1028-K
post #1 of 5
Hi, I've been searching for a new receiver for my home theater and have come across these 2. The main reasons for choosing these are I need 2 HDMI outs.
Can someone please help me compare the 2, and for an extra $300, is it worth upgrading to the 1328.
http://www.futureshop.ca/en-ca/product/pioneer-pioneer-7-2-channel-630w-ultra-hd-av-receiver-vsx-1028-k-vsx-1028-k/10252916.aspx?path=7e1f806d6842c89538ebe86210c24ed2en02
http://www.futureshop.ca/en-CA/product/pioneer-pioneer-875-watt-7-2-channel-network-receiver-sc-1328-k-sc-1328-k/10266245.aspx?path=383190d9499a6ac5a7d0bb152b52abc1en02
I can get the 1028 for $499, and the 1328 for $799
I currently have a pioneer 1014, and am happy with the sound, but it has no HDMI inputs or outputs.
Thanks in advance for any comments, information.
post #2 of 5
I have the SC 1227-k, which is last year's version of the 1328, with the addition of 4K passthrough. Personally I would go with the 1328 because of the D amps. They don't generate a lot of heat, put out a lot of power and can be used with 4 ohm speakers, if you have those. I've had the Pioneer 1014 and 9120, both of which were very good, but I prefer the 1227 hands down. Hope this helps.
post #3 of 5
Thanks for the reply leonardb, any other opinions, comments.
post #4 of 5
No problem. Here is a link to the Elite SC-61, which is almost the same as the SC-1227-k. I imagine that the 1328 internal parts should be the same.
http://www.soundandvision.com/content/pioneer-elite-sc-61-av-receiver
post #5 of 5
Hi, guys , im thinking to buy the sc 1328 k as well does it have 7.1 PRE OUT ?
