AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Can a class T amp be used with my pioneer vsx 822
post #1 of 4
Hi,
I am looking for a way to use my pre out to get a pair of speakers to use as front height. I just wanted suggestions to see which type of amp could be used. I thought about using a class T amp, can it be used for that purpose?
post #2 of 4
Originally Posted by pogo007 View Post
Hi,
yest it can. which T amp you looking at? I have used a Lepai LP-2020A+ in a PC audio set up and overall wasn't all that thrilled with it. It was very noisy, especially at medium and higher volume levels. If I kept the volume level fairly low it was alright, but the volume was too low for my taste.
There are other T amps that are supposed to pretty good, but cost more then the budget lepai i used.
post #3 of 4
I was looking at these two,
Class T Digital Amplifier- 50watts RMS/CH- Sound Appeal- SA-100T
Topping TP20-MK2 MKII TA2020 Class T-AMP Digital Stereo Amplifier
Would they be any good?
post #4 of 4
I dont know if they are any good or not. they do seem more robust then the cheapie $20 one I used.
