AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › help me find an amp for my sub
post #1 of 11
Wasn't sure rater to post this here or the amp thread as it relates to both.
I just bought a Dayton 15 ultimax from PE and cab. I also bought a behringer inuke 1000 amp thinking it would nicely power the sub and now I am thinking that was a mistake as the sub seems to be lacking the kick for my HT I was looking for.
Plus the behringer nu1000 doesn't have the dc power switch that activates with the avr power. I have to manually turn it off and on. I'm going to send the nu1000 back.
My question then is what amp should I purchase for my 15 ultimax sub?
Edited by Thundersnow - 12/13/13 at 2:16am
post #2 of 11
First you need to decide how much power you require to achieve the required loudness. That depends on the sub alignment (sealed/ported/bandpass) and box size among many other things. You need to post in DIY section. iNuke NU1000DSP is one hec of a ballsy value amp. However, I would get minimum NU3000DSP to future proof myself.
You need to gain match your CE gear (AVR) with the pro gear (iNuke) in order for it to perform at its best.
post #3 of 11
+1. Pro gear generally requires a +4 dB signal for full output. Consumer AVRs typically only provide a -10dB signal.
A plate amp.
post #4 of 11
A plate amp.
Is a plate amp really the best route? I hate the idea of cutting a hole in the sub box now that it's built.
post #5 of 11
You asked for an amp that operates at consumer input level and has auto turn on/off. That pretty much means a plate amp. I wouldn't put it in the speaker, that's the worst place for an amp. Make a box for it, put it as close as possible to your AVR.
post #6 of 11
I was wondering if it would be acceptable to place them in a separate housing... Cool!
Seems strange that there aren't consumer amps that come in a case for rack mounting with all the features of a plate amp... am I missing something?
post #7 of 11
Lack of demand. Consumers tend to stick with what's familiar, and on-board amplification is what's familiar, even if it's the wrong place to put an amp due to the ground loop problems that it causes.
post #8 of 11
It is not the best route but one of the better routes. It's kind of plug n play thing.
OTH, you can have huge watts at reasonable price if you go with pro amps. Almost all AVRs have enough pre-out voltage to drive those amps to full potential but you need to gain match them first.
Choice is yours.
post #9 of 11
I'm going to try getting this inuke 1000 working for my setup then if still not satisfied I will look into something else.
I found while reading another thread that I don't have the speakon connectors wired correctly for running the amp in bridge mode so maybe I am not getting all the power that's available.
Thanks for all the help
post #10 of 11
Got the inuke 1000 wired correctly and now the output seems to be on par with what should be expected from 800 watts.
Although I am still thinking about going with something bigger.
post #11 of 11
NU1000 is a good sub, but you need at least NU3000 or similar to future proof yourself.
