AVS › AVS Forum › Audio › DIY Speakers and Subs › cabinet design software?
post #1 of 9
other than speaker builds, i seen where some of you here are building entertainment cabinets and speaker stands. what software are most of you using? im looking to build a cab to house my amps, routers and blue ray player. will Smart draw work or is that over-kill? im looking for something simple. dimensions and cut sheet plans. thanx
post #2 of 9
sketchlist 3d looks pretty simple to use to
post #3 of 9
Google Sketchup is fairly easy to learn, lots of tutorials online.
http://www.sketchup.com/
Once you know the dimensions of your panels, load them up into cut list
http://delphiforfun.org/programs/cutlist.htm
post #4 of 9
wtf is delphi! you have to answer riddles and solve math problems before you can use the program? wth!
post #5 of 9
how in the hell do you use delphi? that site is crazy lol
post #6 of 9
what lol
post #7 of 9
Another vote for Sketchup, and particularly the 3D Warehouse that has many models to download and deconstruct.
The scaling capabilities are powerful and allow easy alteration.
Edited by WVSyd - 12/18/13 at 12:39pm
post #8 of 9
post #9 of 9
sketchup is easy and if you need some help I teach sketchup and have video tutorials that can help here http://teachers.sd43.bc.ca/dpurych/Classroom%20Documents/dreambedroom.aspx
If you navigate the site their are lots of tutorials to help
