AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › SVS PB-1000 or Velodyne EQ-Max 8 Inch Subwoofer?
post #1 of 7
Hey guys, I'm close to pulling the trigger on a SVS PB-1000 sub for my 16X16X8 room....but I came across this certified refurbished Velodyne EQ-Max 8 Inch Subwoofer that's for sale $376.00 near my home....Can anyone draw a comparison? I'll be watching 70/Movies/TV and 30/Music. I have Polk RM6700 sat speakers.....replacing a HTIB Polk PSW250 sub. Thanks for your advice!
post #2 of 7
... I'm close to pulling the trigger on a SVS PB-1000 sub for my 16X16X8 room....but I came across this certified refurbished Velodyne EQ-Max 8 Inch Subwoofer that's for sale $376.00 near my home....Can anyone draw a comparison?
EQ-Max 8
- 8" driver
- 180W RMS amp
- 32-120 Hz +/-3dB
PB-1000
- 10" driver
- 300W RMS amp
- 19-270Hz +/-3dB
post #3 of 7
Not even close between the two. The PB1000 would stomp all over the EQ Max 12".
post #4 of 7
The SVS PB-1000 is the best sub for under $500 based on several reviews I have read. Then the Rythmic LV12R being the best sub under $600.
post #5 of 7
PB-1000 all the way; no comparison.
post #6 of 7
I would go with the SVS PB-1000 without a doubt or hesitation. Best of all it's SVS so you have free shipping and a 45 day in home trial period so if you don't like it you can return it with no cost to you. That type of customer service makes it an easy choice.
post #7 of 7
You guys are awesome! Thanks for taking the time to respond to my post.....smile.gif
