AVS › AVS Forum › Video Components › Home Theater Computers › Media Browser for Roku
post #1 of 24
It has gone live:
http://www.roku.com/channels/#!details/34503/media-browser
Enjoy!
post #2 of 24
I will have to give it a go and test it against plex on the Roku.
post #3 of 24
Originally Posted by lukemb View Post
It has gone live:
Enjoy!
post #4 of 24
Will MB3 allow me to exclude certain folders that are NSFW? Can't have certain videos showing up on the LR TV.
Sent from my Nexus 7
post #5 of 24
Yes. You can create a user profile with it's own library that excludes whatever it is you want to hide. Then you can have a master account that sees everything. You can even take that a step further and hide the master account from login screens so that nobody else will know that it exists.
post #6 of 24
Anyone else having problems with the center channel sound being duplicated into the rear speakers when using prologic II processing?
Edit:
Actually the dialog is coming from all speakers at the same time. Sounds like I have 5 channel stereo turned on, but I don't.
I have 2 Roku 3s one hooked to a Yamaha and one to a Denon.
Both duplicate mono or stereo sound to all speakers. This does not happen with Plex. But I prefer MB3 as a media server.
Edited by Boke01 - 12/21/13 at 5:11pm
post #7 of 24
Thanks. Time for me to get into MB3!
post #8 of 24
Is your movie doing Direct Play, copy video/convert audio or transcode? (press down arrow during playback to confirm...)
post #9 of 24
The ones with problems are 'Convert Video and Audio'.
post #10 of 24
Just to be sure to take full advantage of the Roku, make sure the Roku audio is set to surround (to passthrough AC3 and DTS to your amp), also that your video setting in MB channel is at higher quality than your video file (of course if possible depending on your files)
Besides this, if it still transcode (convert), it may be that the H264 level is higher than 4.1 (Roku limitation).
When HDMI from Roku is in an Amp, the ultimate goal IMO is to Direct Play as much as possible.
But I'm just trying to help doing direct play as much as possible, not saying there isn't an issue with audio transcoding...
I tested Roku with my main amp and it direct plays most of my movies (real AC2/DTS passthrough). But usually I'm on a secondary TV in bedroom/office so it always output to stereo.
Never really tested audio covert to 5.1 surround system (I might test this later a little deeper to confirm if there is an issue...)
Also, if you want, you could post the media info of one of your video file that has this issue (H264 level, bitrate, etc...)
post #11 of 24
I already everything set as you said.
Here is the media info.
Video
Format : MPEG-4 Visual
Format profile : Simple@L3
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 45mn
Bit rate : 781 Kbps
Width : 576 pixels
Height : 320 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.177
Stream size : 590 MiB (85%)
Writing library : XviD 1.0.3 (UTC 2004-12-20)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 1h 45mn
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 97.4 MiB (14%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.58 video frame)
Interleave, preload duration : 306 ms
Writing library : LAME3.90.
Encoding settings : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
post #12 of 24
Ah OK, Roku doesn't support direct play for this video (I guess it's an AVI) so no choice but transcode.
As for the sound issues during transcode, you could get more assistance in MB forums IMO.
But I'll also do some testing on my own to try to reproduce this and, if required, will advise the MB team (they work fast when they have enough information on an issue).
post #13 of 24
Is there some special way to get the ROKU "channel" of MB to display the language for audio and subs?
I used Handbrake to convert a Blu-ray to Mkv with four audio tracks (6.1, 2 ch, Spanish, etc.) and two subtitle tracks(Eng. and Spanish). Although I could choose between them, it did not display which ones they were. I had to restart the movie four times, trying a different track each time b4 finding the correct ones. There does not appear to be a setting for that.
Also, the subs in a regular DVD (Pans Labyrinth), which display nice in VLC, looked bad in MB on the Roku.
The pq was good however.
post #14 of 24
Hey leebo,
Can ask those questions here:
http://mediabrowser3.com/community/index.php?/forum/68-questions-issues/
Our Roku developer can answer those. Thanks.
post #15 of 24
Thank you!
post #16 of 24
Santa brought me one biggrin.gif (ROKU)
Looking forward to playing with it.
post #17 of 24
Dang, I wish I had given you my address. I haven't heard from him in years.
I don't think he believes in me.
post #18 of 24
It has gone live:
Enjoy!
Luke, great work. I have one question. Has the issue of MB Server transcoding iso to Roku 3/ cpu at 90-100% issue been resolved?
Tempted to pick up a Roku 3 and try it again.
Glenn
post #19 of 24
The latest roku version has added stream copy techniques to try and avoid encoding as much as possible. there's also some fine tuning controls within the app itself. if that doesn't help, the next server release will also introduce server-side tuning. so i would give it a shot.
post #20 of 24
Luke as always "you are the man". Your dedication and help concerning MB3 and all of its potential is greatly appreciated.
Glenn
post #21 of 24
I noticed that if I go into a TV show folder that is empty the ROKU will kick back to the "My Channels" screen while in MB3. Has anyone else seen this happen with there ROKU?
post #22 of 24
Hi - I know gcw07 has already applied a related fix for this for the next Roku release. It might be worth reporting in our Roku forum just to be sure it's the same issue as yours. Thanks.
post #23 of 24
Wow. No one here using MB3 and Roku?
Echo.... echo....
Sent from my generic not my computer device.
post #24 of 24
Our forum is probably the best place to get help. The app has recently crossed the 25k download mark smile.gif
