AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › I've got an itch to upgrade from JVC RS-20...
I've got an itch to upgrade from JVC RS-20... - Page 2
post #31 of 38
Originally Posted by sfm View Post
My two cents... I'd still be watching our RS-20 if it hadn't developed the "pink line" issue (at around 2900 hours which represented around 4 years of use)... given that I couldn't live with the pink line (or zooming out to hide it) I went ahead and ordered an RS-56 from AVS... Had it for a year now and it has brighter picture and I lucked into a good one from the convergence, focus, etc. standpoint. I don't see myself replacing the lamp as often as I did with the 20... 600+ hours so far and it is still brighter than the RS-20 was with a new lamp. But even with all the goodness of the RS-56 I still would be using the RS-20 if it hadn't developed the issue (in other words the 56 wasn't a significant enough upgrade in picture quality to justify the money spent). Barring another failure I plan to keep the RS-56 quite a while until reasonably priced 4k projectors become the norm.
Interesting and good info.....I use a twin screen setup with smallish HP screens 92" & 106" (compared to what is generally used around here), use a Darbee at 30%, run a 'S' Gamma curve with the iris at -15, with good source material, I think how much better can this get!....the PQ is so source dependent, one scene is jaw dropping another could be so ordinary. The 'S' gamma curve made a heck of a difference. Use a Sharp 30000 for 3D.
But I look forward to laser/phosphor wheel light source to replace current lamps, true 4K/UHD panels and of course 4K/UHD BluRay....so I'll save a few more pennies towards the replacement as the months go by.
post #32 of 38
Originally Posted by Craig Peer View Post
I'll bet you a beer that those price levels for true 4K projectors won't be seen for 2 - 4 years. And by then - guess what - there will be 8K projectors creeping into the top end ! HA! In fact, I've already heard rumors. wink.gif
And IMO 8k should be the next standard and it should have been called 4k. The jump to "4k" isn't that big of a jump. That's why the marketing folks chose to use the term 4k instead of 2k because it makes the average consumer believe there's a bigger jump than what there really is.
post #33 of 38
Well...I ended up jumping on the B stock Sony HW50ES. After talking with Mike Garrett at AVS, its seemed like a really good deal and value. Truthfully, my JVC RS20 was a B stock deal through AVS and I loved it. This will be my "stop gap" until 4K or 8K or whatever becomes more prevalent. Cheers!
post #34 of 38
I'd love to hear your impressions of the upgrade when you settle into the new one. I've had my RS20 for years now and its the only projector I've kept for more than a year since owning a Panasonic AE100 smile.gif . My major complaints are the pixel visibility from my viewing distance and the motion handling.
post #35 of 38
Motion will be better, especially if you are willing to use FI. However, you will lose a little bit of contrast. On my 2.4HP screen you can see the difference when comparing it to the RS45 I had. I love contrast, but I still prefer the HW50 over the RS45. It's FI created too many artifacts and it didn't smooth out motion remotely close to the Sony (if you like that sort of thing).
post #36 of 38
I sold my RS20 to my pal and I still love watching movies at his place. It's still the most film-like image I've seen on a projector. I never did notice any pixels with my RS20, even though I would sometimes watch it at about 124" wide from 10 feet.
What kind of viewing angle to you have in your set up - quite close?
post #37 of 38
I'd have to agree with that. If anything the newer chassis JVCs look more like a DLP projector than they do compared to the older chassis design JVCs. My RS20 had an entirely organic analog quality to the image that isn't really there anymore with the new chassis design JVCs. That isn't an entirely bad thing but the image feels different.
post #38 of 38
Exactly. I can appreciate the new things the post RS20 projectors bring to the table. They are "different" and have their own strengths. But something was kind of lost as well. Overall, I'm ok with the balance of positives in the new designs.
