AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Can my Denon AVR-1713 drive 4-6 ohm speakers like the old Paradigm 9se Mk3?
post #1 of 4
I'm currently running old Infinity IL10 speakers (really don't know if they're any good; I bought them 10-15 years ago) and my father offered me his Paradigm 9s3 Mk3 tower speakers if I want them.
Thoughts?
Considering buying new front speakers (L/R/C) and maybe rears as well. Happy with my subwoofer. for my system if the Paradigms aren't better. Any suggestions? Prefer to spend $1000-1500 ideally, but willing to pay more if there's good price/performance. Mostly used for watching movies.
post #2 of 4
At moderate TV listening volume levels shouldn't be a problem. For louder movie/music listening the AVR may shut down in protection mode if the volume is raised to high.
post #3 of 4
The IL10 speaker is pretty good. I've owned IL30s IL40s and IL50s in past years. The Paradigm speakers might be better but it won't be a night and day revelation IMO. While I haven't owned the IL10s I have owned the Beta 20 - same speaker with a fresh face. They sound pretty good.
I have the Denon 1713 in my bedroom setup driving 4ohm speakers in 2.1 channel. I don't drive it hard. I doubt it has the omph to drive a 5 channel 4ohm rated set of speakers. For 2 channel it should do ok. I would stick with 8ohm speakers for a 5 channel setup.
post #4 of 4
Thanks, much! I'll stick to my IL10s then.
