AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Connecting devices to a Samsung F450 sound bar..
post #1 of 3
Hello All,
Hope you had a good Christmas :-)
I need some help with my set up please.....I have just brought a Samsung sound bar and I am unsure what is the best set up as I do not have enough HDMI ports on my TV.
I have
Samsung 40'' LED TV : UE40EH6030
SKY+ HD Box
PS4
Samsung F450 Sound Bar
The TV only has 2x HDMI Inputs and I want the sound bar to take all the sound from the 3 devices without any lack of quality, how can I set this up?
What would I need to buy to allow this to happen?
Thanks in advance
AzCoop
post #2 of 3
Since the soundbar has only one HDMI input, you may need a HDMI switcher with at least 3 HDMI inputs (and one output).
Check out www.monoprice.com
post #3 of 3
Thank you for the reply, I was guessing that I would need a switch.  So for the set up I would need to connect the Sound bar to HDMI on TV and then connect the Sky HD & PS4 to the switch?
Im in the Uk so I can not get the Monoprice products, do you know of any products that I can get in the UK for around £40?
