AVS › AVS Forum › Audio › 2 Channel Audio › Matching Martin Logan aeon amplifier
post #1 of 8
I have been using in bi-amp mode a nad 3300 and 2100. I was wondering if there is a better amplification for less than $1000 that I should consider and that would provide a significant difference. I am not trying to get an upgrade for the sake of spending money. I am using Martin Logan aeon. Thank you,
post #2 of 8
Significant difference in what? Guessing that you mean sound quality then the answer is no. You are trying to upgrade just for the sake of spending money.
post #3 of 8
Thank you for your answer. Yes , I was asking about sound quality difference and i am not interested in upgrading for the sake of spending money. Thank you again,
post #4 of 8
The NAD gear you have is probably better than anything you can get for under $2000 in a separate amp and preamp. It is not too bad.
On the other hand, for $1500 you can get a Musical Fidelity M3i integrated amplifier, which I know from personal experience has a clearer more musical sound quality than the NAD gear. Been there, done that.
It is a cut above anything else in its price class IMO for sonic purity and listening to well-recorded music (although Arcam is right up there too).
You have some very fine speakers there and one of the better integrated amplifiers would really help them to perform a lot better. The NAD gear is fairly good, but not really in the same sonic class as the speakers.
They don't need a huge amount of power, and the M3i has close to 100 watts at 4 ohms.
Edited by commsysman - 12/29/13 at 10:01am
post #5 of 8
Thank you so much for your message. This is exactly the information I was looking for. As I was not looking to invest $1500 or so in an amplifier and although I heard great things about musical fidelity, would you advise to go for used material such as accuphase or mcintosch? Thank you again.
post #6 of 8
Relevant parameters include how far you sit from the speakers in your preferred listening position, and what average and peak SPLs you listen at.
With 89 dB/W sensitivity and rated for "4, 6, or 8" ohm speakers, your Aeon's aren't particularly tough loads.
60 wpc isn't a lot of power. Your speakers can handle much more power if it is required by your listening preferences.
If you don't have a SPL meter with a peak hold facility - they are easy enough to obtain, for example:
http://www.ebay.com/itm/8928-Decibel-Meter-Digital-Accurate-Sound-noise-pressure-Level-tester-40-130-db-/271167212819
Just put it where you sit and punch a few buttons, listen to some music as loud as you like, and read the digits and post them...
post #7 of 8
The room is about 500 sqf and the typical listening distance is about 10 -12 ft from the speakers. Depending on the source and the type of music the volume button is between 1/3 and 1/2. I use the two amps in vertical bi amp and was advised not to bridge them. I am happy but provided the age of the amps I was wondering if there is a better solution at a reasonnable cost. Thank you for your time and expertise.
post #8 of 8
Given what you've described, there probably isn't a better solution even at unreasonable cost. You have enough power. You're fine.
