AVS › AVS Forum › 3D Central › 3D Displays › Looking for ir 3d glasses compatible with panasonic 50st60
post #1 of 2
Which other ir 3d glasses will work on the panasonic 50st60?
post #2 of 2
Only universal RF (Radio Frequency) glasses will work with the Panasonic ST60, not IR (Infrared). So, try any active Samsung 3D glasses. There are $20 Samsung glasses that will work, however, they're battery operated and do not give you as nice of a 3D experience as the $50 Samsung rechargeable ones can. However, since Panasonic and Samsung have all met the Universal Active 3D standard. Supposedly, any active 3D glasses should be able to pair up, as long as they are RF from what I understand.
  Back to Forum: 3D Displays
