AVS › AVS Forum › HDTV › Local HDTV Info and Reception › I live in Kannapolis and wanted some advice from a more local flair
post #1 of 3
Thanks in advance, looking for the correct Antennae
http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d46ae249f29c188
post #2 of 3
You would do better to look at the Charlotte OTA thread...
http://www.avsforum.com/t/486246/charlotte-nc-ota
post #3 of 3
Clearstream 2V from Walmart and possible amp should get all major Charlotte stations, as well as WTVI. And you should also receive Greensboro with a good UHF antenna and amp if you choose. Perhaps an 8-bay or 43XG. There is DB8e, CM-4228, and generic versions from MCM and Solid Signal that are lower priced. And the Antennacraft HBU-33 from RadioShack could also be a good choice. But should post in Charlotte OTA thread.
