AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Aux Cable for Iphone5
post #1 of 3
I recently purchased the 1122k receiver and I'm trying to wire the iphone 5 directly to the receiver, how do i go about doing this?
I am aware of the airplay, i am able to do this but there is a lot of lag. I prefer wiring it directly to avoid this problem. The cable which came with the receiver is only meant for the iphone 4. I have an aux cable, but i am not able to find a place where to connect to this on the receiver, can someone please help?
post #2 of 3
Apple sells a Lightning to 30 pin adapter which will adapt the port to that of the iPhone 4. You can find equivalents for far less money.
post #3 of 3
This cable will also work. 3.5 out from the headphone on the I-Phone to any open analog on the back of the AVR. Go to that input on the AVR and your'e good to go.
http://www.monoprice.com/Product?c_id=102&cp_id=10218&cs_id=1021817&p_id=9767&seq=1&format=2&utm_expid=58369800-11.KFcpHWqASSutMqNPOqaJVg.0&utm_referrer=http%3A%2F%2Fwww.monoprice.com%2FCategory%3Fc_id%3D102%26cp_id%3D10218
These can also be purchased from Wal-Mart or Radio Shack.
