AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 1613 center channel sound quality
post #1 of 10
I have a new 1613 receiver with 3 speakers configured + sub(no surround speakers). In dolby digital , the center channel always sounds restricted(missing lower and very high frequencies). When switching between dolby digital and stereo listening modes, the sound in stereo is a lot clearer. I assume that when switching to stereo listening mode, the material from the center channel is simply distributed to the left and right speaker. The problem seems to be unrelated to dynamic eq. It exists with dynamic eq disabled and even in pure direct mode. It seems like a dolby digital decoder problem.
It may be just the way dolby digital works, I am not sure. I do not have another receiver to verify that.
Gear mentioned in this thread:
post #2 of 10
Have you run the receiver's Audyssey calibration?
It should both flatten (make more accurate) the frequency response of your speakers in your room and set their crossover frequencies so that the low frequencies that they can't reproduce well get diverted to the subwoofer.
You should also place the center channel speaker so it extends beyond the front edge of whatever shelf it's on, and tip it up or down (as appropriate) so that it points more directly toward your ear height at the primary listening position.
There are some other things to consider. If you haven't already, please take the time to look through the Audyssey 101/FAQ. The instructions in the receiver's owner's manual are woefully inadequate. See http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-51779/51750#post_21782993
post #3 of 10
Yes, I have run the audyssey calibration. I have setup all 3 speakers on the same level with no obstruction. All 3 speakers are the same.
Like I said before, even in Direct mode(audyssey settings ignored) the sound from a dolby digital source is worse than the same source run through the stereo listening mode. I am inclined to think that this is simply the way the material was encoded(the way dolby digital works) or there is a problem with the receiver's decoder. So if somebody can do the following test, let me know what the results are:
Listen to a dolby digital program , then hold one of the listening mode buttons on the remote for a second, which will allow you to switch to Stereo, Neo, etc.  and let me know if the sound changes dramatically.
post #4 of 10
Hi, to tell you the truth it's a bit difficult to follow what your problem actually is. Care to rephrase what you are hearing in different modes?
post #5 of 10
Sure. In Dolby digital mode: muffled sound. Emphasis on voice(probably 0.3 to 3Khz) with missing or very low amplitude of frequencies above that. No "presence". Speech unintelligible. In stereo mode everything comes back to "normal".
I know it is difficult to explain.. that is why I was hoping someone would perform the same test on their receiver and tell me what they hear.
I appreciate your help! btw, I am new to the forum, so please let me know if I am doing something wrong :)
I am seriously contemplating returning the receiver.
post #6 of 10
I appreciate your help! btw, I am new to the forum, so please let me know if I am doing something wrong smile.gif
Before returning the receiver you always have a last resort: "reset the microprocessor" (read: do a factory reset). Look up the Manual for procedures and report back please!
post #7 of 10
Three possibilities occur to me:
1. the center speaker is damaged
2. its cable is damaged (although that usually would make the center speaker silent)
3. the circuitry in the receiver associated with the center channel has failed. (Resetting everything several times might fix this.)
You can try exchanging the cables running to the center speaker with those running to the Left or Right speaker. Play a known-good multichannel soundtrack. If the sound coming from the center speaker is still muffled, then the speaker probably is at fault. If the sound coming from the Left (or Right) speaker is muffled, then the problem most likely is in the receiver.
When playing a multichannel soundtrack, most of the dialog is sent to the center speaker channel. When the receiver is playing a multichannel soundtrack in stereo mode, the center speaker channel is not used at all. Instead, the audio that was recorded on the center channel is divided equally among and sent only to the left and right front speakers.
post #8 of 10
Since you have 3 of the exact same speaker, swap the center with one of the others to see if there is a difference.
I have that same receiver and don't have any of the problems that you do.
post #9 of 10
It is not the speaker. I have used several different speakers, same result. It is not the cable either. If I switch to multichannel stereo for example, the center channel comes alive, just like the left and the right. The bad sound quality is with Dolby Digital material. I think the decoder in this receiver is bad.
post #10 of 10
swaping speakers does not help. Since you have the same receiver... Do you notice any difference at all in the sound quality when switching from dolby digital to stereo? Do voices keep their clarity in both modes?
