AVS › AVS Forum › Audio › 2 Channel Audio › Technic SA-GX730 receiver (sub-woofer installation question)
post #1 of 3
Okay seriously, I've managed to get all of the surround sound system (Optimus) hooked up to my Technics SA-GX730 receiver... at least until I got to the sub-woofer.  I have searched for the manual... nada.  Thus far I haven't had much luck online either.  Computers are my thing normally not stereos.  Can anyone out there give me a shove in the right direction as to where in the hell I hook up the sub-woofer to the receiver and/or which settings I'm supposed to tweak to get the damn thing to work properly?
post #2 of 3
I have posted several instruction on how to do this..
You can go through my post, I posted several instruction on how to connect them. There are a few ways to connect them depending on the subwoofer that you have.
http://www.avsforum.com/newsearch?advanced=1&action=disp&search=speaker+level&titleonly=0&byuser=qguy&output=posts&replycompare=gt&numupdates=&sdate=0&newer=1&sort=relevance&order=descending&Search=SEARCH
post #3 of 3
Thanks, man, got it.
