AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pioneer VSX920.....Is it good?
post #1 of 10
Hi
Is the Pioneer VSX 920 a good receiver (mainly for HT but I would like to enjoy listening classical music as well)
What would be a step up without breaking the bank?
Or any receiver significantly better in terms of sound quality will be much more expensive?
post #2 of 10
Originally Posted by french_guy View Post
Hi
What is your budget?
What is your room size and what are your speakers?
I am also curious why you are looking at a three year old receiver.
post #3 of 10
According to this thread of his from earlier today, it's the AVR he currently owns.
post #4 of 10
Yes, I own one
I was wondering if I could find something better. I've read somewhere the VSX920 was not so great after all....!!!
post #5 of 10
Sure you can get something better but you have to tell us how much you're willing to spend...
post #6 of 10
I haven't thought about a specific budget......
But my receiver is acting weird. 2 days ago, I had no sound on the 'BD" input, and I had to reset the unit to get it back !!!
So let's put it that way: what would be the cheapest receiver that is better than the VSX920 (I want at least 4 hdmi inputs, with upscaling of the component inputs since I have a Wii and PS2)
Any good recommendations on Accessories4less for example?
post #7 of 10
If you can don't need 7.1, the Denon 1613 should suffice nicely.
post #8 of 10
I don't think I can install a 7.1 system in my room. I will have to stick with a 5.1
Is the Denon 1613 really better than the VSX920?
post #9 of 10
Hi bladerunner6, the Denon 1613 doesn't upconverting / upscaling the component input back through the HDMI output.
post #10 of 10
Originally Posted by JChin View Post
Hi bladerunner6, the Denon 1613 doesn't up converting / upscaling the component input back through the HDMI output.
Thanks for pointing that out.
