AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › Suggestions for 130" AT screen using milliskin spandex material (white matte/shiny gray)
post #1 of 9
I am getting ready to build a 130" AT screen using the milliskin spandex material. I have been reading lot of posts discussing the various combination of White over Light Silver/gray Matte Milliskin screens or vice versa with different results. It does seems like a good solution for the AT screens on a budget.
I didn't find anyone using a combination of matte and shiny milliskin layers and I was wondering would it improve the results if I use the white matte milliskin on top and a gray shiny millskin under it. Would it improve the results or if anyone has tried that already..
post #2 of 9
No Suggestion? Come on guys, I know there are lot of talented people on this forum and I am sure someone has tried this option smile.gif
post #3 of 9
You have a answer in your PM box to your PM'd request. Proceed accordingly, and re-post it if you like.
post #4 of 9
Same question for me !
Light Silver/gray Matte Milliskin are no longer available !
post #5 of 9
Any standard Light Gray Milliskin will suffice.For those who desire a maximum increase in Contrast off a White top layer of Milliskin, you can use either a Black or Dark Gray Milliskin as the bottom layer.
http://spandexworld.com/c3/catalog/product/6201
post #6 of 9
That is pretty much what I did when making my screen. I used dark gray under white. I used spandex from local JoAnnes and I am very happy with my screen.
post #7 of 9
post #8 of 9
People have talked about the shiny silver but I haven't seen any postings of results. The shiny silver might cause issues with the image or might be useful to increase the gain. Until someone tries it and posts about the results we won't know for sure. If you don't want to experiment, this should work http://spandexworld.com/c3/catalog/product/6201
post #9 of 9
I know.....
Anything truly "shiny" behind a translucent material such as Spandex risks imparting a glare....or hot spot.
  Back to Forum: DIY Screen Section
