post #1 of 1
Does anyone know the difference between the 2?
I know the DLS R6.2 is a replacement for the R6A. I'm also not sure which is the newer/older of the 2 sets. I was wanting to go with these because the research I've done says that they have top quality sound and the tweeter isn't "bright" like most other component speakers on the market (Focal, Massive audio, Image Dynamics). They are also right around $200, which is all I'm willing to spend on my front components.
There's also a set of DLS Reference UR6S that I can get in the same price range.
R6.2 Specs:
6.5" 2-way component with a sound in top class
Brand new mid range driver and cross over
The mid range cone is made from black coated fiberglass,and the T-yoke is copper covered
Due to the features above the bass is more tight and the mid range have higher resolution
The tweeter in this system is T-25, 25mm soft dome
The parameters are fine tuned to play perfect in a car door
Powerful magnet system
Cone made of black coted fibreglass
Crossovers with selectable tweeter level
25 mm silk dome tweeter T25
Grilles are included
Specifications:
Woofer size: 6.5"
Tweeter: T25, 1" silk dome tweeter
Power handling (RMS): 100 Watts
Power handling (Peak): 200 Watts
Impedance: 4 ohm
Frequency range: 30-20 000 Hz
Sensitivity: 90 dB
Crossover: Filter box with 6/12 dB slope (LP/HP)
Crossover point: 5000 Hz
Size of filter box: 5.71" x 3.35" x 1.77"
Outer diameter of woofer: 6.5"
Magnet size: 3.94"
Mounting depth: 3.07"
Mounting hole: 5.5"
RM6.2 Specs:
Power Handling (Peak): 200 watts
Power Handling (RMS): 100 watts
Dual midwoofer surround
Crossover point (Hz): 4500 Hz
Crossover Filter box with 6/12 dB slope (LP/HP)
4-5/16" neodymium magnet structure
6-1/2" Reference Series 2-Way Car Component System
Aluminum midwoofer cone material
Multi-mount silk dome tweeter
Single crossover box for both mid and highs
4 ohms impedance
Top-mount depth: 2-13/16
Thanks for looking
