AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › IR Code for Motorola HD-DTA100u from Comcast or Xfinity
post #1 of 6
Does any know the IR Code for the Motorola HD-DTA100u from Comcast or Xfinity? I have looked and can't seem to locate it. Really hoping to get this up and running. Thanks!
post #2 of 6
Or does anyone how to find out? Like what processes others have used to learn? Thanks.
post #3 of 6
It may or may not exist.
But one thing is certain... If the box you are attempting to control makes use of RF, you are SOL, because RTV's can only control IR STBs.
In addition, I recall there was some type of newer IR remote that no .rid file can be created, because is uses some type of different protocol.
I am one in the camp that is, "If something isn't broke, then why bother replacing it?" However, newer devices require much more in way of button presses that they move on.
Suggest you visit Planet Replay and the JP1 forums for help.
Have you exhausted every code in the RTV?
Cheers!
-Doug
post #4 of 6
Doug, Thanks for your response. Unfortunately the box doesn't turn off, which makes it hard to test the codes because that is the default option. I didn't want to make a switch, but my ota got worse and they offered me free local cable. Not sure if I will be able to get it to work though. I will check those other forums you mentioned too. Thanks again, Erik
post #5 of 6
Don't know about the DTA100U, but I use 4476 for my Comcast Motorola DTA100
post #6 of 6
Thanks, I will give that one a try. I am getting a new ir cable too, so I will let you know what happens once I get it.
  Back to Forum: ReplayTV & Showstopper PVRs
