Fiber Optic Star Ceiling
post #1 of 2
Hi,
  I am putting in a custom theater and looking for high end fiber optics system or fiber optic panels. I will be doing a coffered ceiling and I am not yet sure of the sizes as they may be slightly different than normal 4 x 4 etc. Maybe I should do a custom and have someone install the fibers. Any suggestions for nice star ceilings are greatly appreciated!
post #2 of 2
There are places that supply custom-sized solutions out there. Typically what is done is provide your exact finished measurements. Then the panel(s) are built one inch shy all the way around and trim (usually black) is applied around the edges. This way you can get a custom solution shipped to you without building it on-site, making installation very easy. PM me for more information, please.
