AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Wallmount Candy/Concession Paper Towel Holder
post #1 of 3
This is my brainstorm for a wallmount holder for candy and a paper towel holder. I used clear containers that were once used for roasted peanuts purchased at our local grocery store. I removed the labels and built the shelves to fit perfectly to there measurements. Textured paint from Lowes applied with a clear coat and bingo i have a candy display at eye level. What do you think?
post #2 of 3
nice what are the demensions
post #3 of 3
The dimensions are 10 1/2 " x 18" and each shelf is 6 inches deep. This works great. using previous roasted peanut containers for candy. I used a flush mount picture bracket to hang it to the wall. The underside and rear are not boxed in, just painted flat black and a cross memeber attached on the bottom for the paper towel holder.
