AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Ditch Epik Empire for two Rythmic subs?
post #1 of 10
With Epik officially going belly up, and to temper my insatiable appetite for an upgrade, I’m thinking about selling my Empire and replacing it with two different size Rythmic subs. I could go with matching F12s but I worry that I’d be losing output coming from two 15” woofers. I could fit a FV15 where the Empire sits today, which is near field next to my sofa, and a F12 upfront next to my Sierra towers.
I know this is very subjective question, but do you think dual Rythmic subs will provide a better overall experience (output and sonically) than my single Empire? I have a Denon 4311 so both subs will receive proper calibration.
post #2 of 10
Usually best to get two matching subs rather than two differing in performance. Regardless if one will be near field or not.
Rythmik provides a nice product along with several other ID companies. I own a Rythmik and have been quite pleased with it.
If you can't afford dual FVHP15 go for dual FV15.
Best Regards
KvE
post #3 of 10
A single FV15HP easily bests the Empire in almost every frequency as it should given it costs substantially more. You can check out the measurements of both subs at data-bass.com.
post #4 of 10
Thanks for the suggestion! I tried accessing the website but Google Chrome can't connect to it for some reason. Will try again later. Would love to check out some ratings and specs.
post #5 of 10
The 2 rhythmic subs will outdo a single empire. No doubt. After selling the empire, I would get the FV15HP and see how it sounds. It may be enough to satiate you. If you still want more, then consider adding a second sub.
If you want 2 non matching subs, why are you selling the empire? You won't buy a better sub for what you'll get for it. Why not just add a second sub?
post #6 of 10
You may also want to look at PSA subs. Like dual XS30s or 1 XS30 and 1 XS15 or dual XS15s.
post #7 of 10
btw the FV15 is no longer available.
post #8 of 10
That's a great question. It really boils down to getting rid of the Empire while it's still working. If/when the amp dies the resale value will be equivalent to a pack of gum, and I'm not inclined to go down the DIY amp route since it requires some soldering, etc. Who am I kidding? It's a case of upgraditis smile.gif.
post #9 of 10
(have I ever mentioned how much i love my FV15HPs?)
Have you checked out the first couple posts in the ULF thread?
post #10 of 10
I think a single FV15HP is a great option. But, if you want to save a little money I agree with flick and suggest you consider the PSA subs.
