AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › A New 2.40:1 Sintra Screen with Silver Fire v2.5 4.0
post #1 of 5
This project is the 1st of 4 upcoming Screen builds.
To start this project out I selected 4 pieces of clear, straight 1" x 8" Poplar....2 pieces at 12' and 2 pieces at 5'.
I decided to do the corners as "Butt" joints supported with Simpson Strong Tie "Flat L" Brackets, because I am overlapping the Poplar on all sides a full 5 -1/2" with the 10' x 50" Sintra, the latter being glued in place with Heavy Duty Clear Power Grab adhesive.
Here are photo depictions of the process / build up to but before painting commenced this afternoon.
Having started spraying at just before 3 pm today, I have finished applying 6 coats of SF onto a 10' x 50" sheet of Sintra in just 3 hours. I used a 1.0 mm needle, and the Duster method, assisted by raising the room temp to 78 degrees and using a 20" Pole Fan set at 7' from the center of the screen. Time between coats was just under 25 minutes.
The extremely small droplets a 1.0 mm needle produces, combined with sufficient room temperature and increased air circulation had everything to do with the dry time. But most importantly, the surface of the painted Sintra was incredibly smooth, with NO vestige of paint texture.
Tomorrow will see a Panasonic AE 8000U in place, and some Screenies...of course. I have the Pole Fan going on Medium, and the Temp being maintained at 72 degrees all night, so the paint should be very dry, if not fully cured.
Stay tuned.
Note:
Upcoming over the next 3 week period...a Dual 180" Drywall Screen project for a Church Sanctuary, 2 separate 143" 2.40:1 Screens, and one itty bitty 130" 2.40:1 screen.
Overall, these projects will encompass a wide variety of build techniques and performance criteria, so I hope they will inspire and educate those needing such encouragement and assistance.
post #2 of 5
So the day before yesterday the paint was applied and left to dry overnight. Yesterday i took down the Plastic, and removed the Cardboard masking.
Time restraints did not allow for my being able to hook up any equipment, but that is on the agenda today after Church. I did take some side view shots that show the smoothness of the paint application.
post #3 of 5
I didn't get to take many images....I wanted to get done assembling the A/V Rack and get home to watch the Denver & SeaHawks Games.
Here are three quickies, two in warm ambient light, one in very low ambient light.
post #4 of 5
It seems that these type of rooms has become your signature build. Nice screen!!! smile.gif
post #5 of 5
Yeah......,
Since a majority of the jobs i encounter involve existing Homes, and in those Homes there are "Bonus Rooms" above Garages that have "Knee walls", I get a raft of them all the time.
Still, I also have at least 3 upcoming that are "Square Framed" and one is of huge proportions (32' x 28') so at times I catch a break.
The room above is a full 32' "long" at the left side of the image, with two equally spaced windows where I could easily have placed a 140"+ screen, and a row of 6-8 Theater seats under the "slope". But no...the "Lady" had to have 3 rows of 4 Chairs so the room had to be designed on the long axis, with a 2 level Riser. Why? Because she wanted a "Stage" for the Kiddies to put on little Shows for Guests. :rolleyes"
That installation will soon be featured in a separate Thread. But I'm still not happy, even though the sound will feature a 6 Transducer x 3 Channel Front Sound stage powered by a 3 x 325 watt Emotiva Amp.
(BTW...The "Hole" with Transducers will receive a 54" x 10' Drywall "plug")
  Back to Forum: DIY Screen Section
