AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Get TV output to P.C.
post #1 of 6
Is there anyway to get a Vizio 501D output to a P.C.?
I didn't notice any video output jack on the TV. I was wondering if there was some 3rd party tool or a way to do it wirelessly or maybe one of the usb jacks.
post #2 of 6
HDMI ?
post #3 of 6
If there are no video outputs on TV, Why ask?
Bottom line is... No.
post #4 of 6
I thought all the HDMI jacks were input type?
I was hoping for some wireless/usb device that could send a picture(degraded) to the P.C.
This way I could remote in and watch football on the p.c. and get some work done at the same time.
post #5 of 6
What you want to do is look up Ceton Corp. They make an HD tuner you can stick on your network and stream video to all of your PCs in your home.
Good luck.
http://cetoncorp.com/products/infinitv-6-ethernet/
post #6 of 6
Input going into a TV, output when leaving a tuner or DVR. Any tuner would/should work. Audio is another matter.
TV's are input devices, not output.
