AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Can't change Dynamic EQ in Denon 1912
post #1 of 4
Hi,
Weird question - for some reason when I go in to my menu and try to tinker with dynamic eq, i can't. I see it right before i click on audyssey settings, but then once i click that my only option is to change multeq from manual to off.
Is there a different place i should be trying this?
Gear mentioned in this thread:
post #2 of 4
Have you run the auto setup? You need to run it before audyssey and deq can be enabled.
post #3 of 4
I did but it was a while ago. I think you must be right though because it's not coming up as an option.
The setup is when I use the microphone right?
post #4 of 4
Correct
