AVS › AVS Forum › Audio › 2 Channel Audio › Which turntable to choose, Music Hall mmf2.2 or Pro-ject Debut Carbon
post #1 of 5
Hello everyone,
I got to replace my old turntable and my choice stopped at either Music Hall mmf2.2 or Pro-ject Debut Carbon.
I read great review about the Pro-ject Debut Carbon, however I mainly listening at some Rock, Alternative and some Country music. Some of the review I read complains about the lack of kick when listening at this music type.
My new turntable will be connect to my Stereo Rotel RC-1070 pre amp with power amp RB-1070.
Do you guys have any advise concerning those two turntable ?
Thank you
post #2 of 5
This isn't really what you want to hear, but there isn't a lot to choose between them. Partisans can give you specious arguments for one or the other, but you'd do just as well to flip a coin. If it helps, you can't go wrong either way.
post #3 of 5
And Pro-Ject makes the turntables for Music Hall, so there is likely to more in common than;) different!
post #4 of 5
Right. Same basic design, and made in the same factory.
post #5 of 5
The turntables are quite similar, but I am partial to the Music Hall version.
Any sonic differences will be between the cartridges that come with them, which are pretty basic.
You can spend $200-300 for a better cartridge and that will be a major sonic upgrade for either one.
A Musical Fidelity V90 LPS phono stage will also be a big improvement.
