AVS › AVS Forum › Audio › Speakers › Need help with Crossover Settings
post #1 of 16
Have L&R Rti5's and a Csi6 for center. Rti3's for L&R rears in 5.1 system. Need to know what crossover settings I should use. Have 15" Hsu sub. Currently have 5 speakers the same at 60hz. Thanks for the input. Seems like the rears are very hard to hear even when I set their volume way up.
post #2 of 16
Well, surrounds aren't rears, they're surrounds (to the sides is the general intention in a 5 ch system) and there's not a lot of content in the surrounds generally as compared to the mains. What avr do you have? Are you using the auto speaker setup routine/room correction software in it? 60 isn't a bad starting point, although you might try the THX suggested 80 or something in between as well....
post #3 of 16
AVR is a HK3600. Originally used HK system to set up but since have been doing it manually. Room is rectangular with rear wall a long distance from tv.........30 ft. Will see about placing speakers to the sides vs behind. Just looking for a starting point to know I am somewhere close to where the crossover settings should be set. Really do not even know what the function of setting the crossover freqs are. Thanks for the suggestions.
post #4 of 16
What input do you have the RTi3's hooked up? Surrounds or SB(Surround Back)
Have you used the "EzSet/EQ automates room-equalization and system-calibration for simple system setup and optimal audio quality in any listening room."
Crossover from 60-80hz should be find though I don't think the cross over is the problem for lack of volume with the surrounds
post #5 of 16
Use the automatic setup for levels and delays (AKA distance).
The function of the crossover is to separate the deep bass from the main channels and send it to the subwoofer.  The reason for that is that the subwoofer can generally handle deeper bass than the main speakers can.  If you send the deep bass to the main channels, whatever they cannot reproduce, you do not hear, plus they will distort more trying to reproduce frequencies that they are ill suited to deal with.
I would probably go with an 80 Hz crossover.  You want your speakers to be able to go lower (at their -3dB point) than your crossover point, and although they are all rated for lower than 60 Hz, it is a little closer than I would recommend for 60 Hz.  Try 80 Hz and see how you like it.
post #6 of 16
I wouldn't go lower that 80hz. And the "rear" or back surround speakers seem to be much farther from the listening position than the front so you might need to up the trim on them.
post #7 of 16
so do I set all 5 speakers to 80?
post #8 of 16
I would. Maybe even 100 for the surrounds.
post #9 of 16
Polk RTi A3's are -3db at 50hz. They will be fine with a 80hz crossover
post #10 of 16
another confirmation of 80hz...
post #11 of 16
Not familiar with that avr or its setup/room correction software....is it ezset? I've heard of that but not familiar with it....
Where's your listening position in this room and what are all three dims of the room?
You don't specify a sub, what is it? You can't crossover anything unless you have the .1, a sub....
post #12 of 16
He states system is 5.1.
Room size or LP really has nothing to do with the xover setting.
post #13 of 16
I'm more curious about his setup and how he got there is all. He states .1 but doesn't mention a sub....
post #14 of 16
sub is a 15 inch Hsu
post #15 of 16
This was what got me curious about if you had a sub or not.....what did you mean by this?
post #16 of 16
Refer to this website for proper speaker placement.
I would also recommend using the auto-EQ on your receiver, it does more than just set a crossover. Using the mic it will determine the levels to set each speaker so everything is matched. The only way to do this yourself is with an SPL meter.
Also just out of curiosity, I assume you have the HSU VTF-15H, what do you have the knobs on the back set to?
  Back to Forum: Speakers
