AVS › AVS Forum › Home Entertainment & Theater Builder › Game Room Equipment & Accessories › Shuffleboard Powder Problem
post #1 of 6
I just finished building my 22 foot shuffleboard and used an epoxy resin on top. Does anyone have tips for how to prep the table once the epoxy has cured? I coated it with sunglo silicone spray and Sunglo speed 1 powder. The pucks push all the sand out of the way every once in a while and go about 5 feet. I will do a writeup on the build with pictures when I'm not on my phone.
Any thoughts on what could cause or fix this?
post #2 of 6
Use a shuffleboard cleaner/polish first. Then put a coat of auto carnauba wax on and buff. Then spray your silicone in a fanning motion about 18 inches from the surface( just let the silicone just fall down) then put your powder down the same way
post #3 of 6
Thanks for the advice. I'll give it a shot and let you know what happens.
post #4 of 6
Forgot to mention I use triple crown brand products. There are tons of brands to use but these are my preference
post #5 of 6
I have tried just about everything and I am still having the same problem. Do you think this could have something to do with the pucks? I bought sunglo pucks and after looking at the bottom they only appear to be wearing or scratched on the edges.
post #6 of 6
It may be your pucks, some pucks are flatter than others and they may be not riding on the true bottom, but I doubt it are they big scratches or just wear type scratching. If you did the epoxy it should be a nice smooth surface, maybe try a different silicone and powder, maybe you got a bad batch, you got any pics of your build yet?
