AVS › AVS Forum › Audio › 2 Channel Audio › Headphone Stands?
Headphone Stands?
post #1 of 18
I'm new to the forum, but work with a hi-performance, high-end audio manufacturer, and we have a lot of headphones in our office, and have decided that maybe we need to manufacture a headphone stand that does more than just keep your headphones off the floor.
Any thoughts on what other functions a headphone stand should have other than holding your headphones?
Thanks! I look forward to any and all input! :D
post #2 of 18
Something to hold or wrap the cords.
post #3 of 18
Have you checked out the Geek Force forum on the designs some people are submitting? They are definitely on the same page. Awesome ideas.. very creative!
post #4 of 18
linky?
post #5 of 18
post #6 of 18
I guess I'm still too new to this forum, not allowed to post links yet.. but you can go to LH Labs dot com and check out the yellow highlighted announcement tab when you get into the forum.
My link might pop up once it's approved.. :confused:
post #7 of 18
post #8 of 18
Funny! It could work.. not well, but I bet someone has tried! :D
post #9 of 18
Originally Posted by bellageek View Post
Indeed, *someone* has. Have a pair of Denon D2000s that rest on them. They are cheap, but look expensive and sleek and European.
I have some of your products and love them, but what I have works well and is a lot less expensive.
post #10 of 18
thank you!
post #11 of 18
Originally Posted by Will2007 View Post
now thats pretty cool!
post #12 of 18
...and then you can use it like a Mr. Potato Head.....
post #13 of 18
post #14 of 18
^ thanks muay!
post #15 of 18
Just in case this one is the Banana holder from Walmart ($6).
post #16 of 18
Not very high end, but I have one of these screwed into the underside of a number of computer tables for exactly the purpose you have described.
Drilling a pilot hole helps with the installation.
I'm thinking that some flexible tubing could make them look a little more high tech.
post #17 of 18
I use this: Glass head
2188209.jpg?sw=400&sh=400
post #18 of 18
I use this stand also from Bed,Bath and beyond just added some clear tubing to the hook to protect my headband.
