AVS › AVS Forum › Audio › Speakers › Boss Bookshelf Speakers
post #1 of 10
And lot's of knowledgeable people so i've returned.
I'm in the Market for some Boss Bookshelf speakers- Wouldn't mind some help as I'm a bit out on the current gen of audio. (It went to crap)
Very limited space in my house, and a choice set of Bookshelfs are about all I can handle.
I'm currently looking at the Ascend Acoustics Sierra-1s, but want advise from others out there for similarly priced speakers.
To power them, I was thinking the Denon AVR-X1000 to power them, (unless I should be looking at something else)
It sure would be nice to find a solid tube-amp that won't break the bank.
post #2 of 10
Boss? Is that a white van version of Bose speakers?
post #3 of 10
Boss is a very low budget band. Not bad stuff just low end. They come from a Car audio background. I would see no reason for someone to post on here about looking specifically for Boss.  I really think he meant Bose but if he reads much on here, it won't take long for him to see that pretty much no-one on here will recommend Bose over much better for your money options. Just my $.02 worth from the short time I have been around here.
post #4 of 10
I think he is using slang....like a "bangin system" bc he does mention Sierra 1s.
First we need a little more info, Price, what will the system be used for, movies? music? Size of the room. Do you plan on running a sub or just the speakers?
post #5 of 10
Lol
Yes, I meant the slang term. I'm looking for some "Diesel" speakers. smile.gif
Price- Somewhere around the same as the Sierra-1s
$1,000 to $750 Range.
System will be used for just about everything as the centerpiece in a really small house- Movies, Playstation 3, Spotify, iTunes library.
No sub- Only speakers.
And I'll actually be using a old re-purposed Boston Micro 90c Center Channel.
I know I won't find anything that matches up to that perfectly, and that's OK. It's going to be 2-channel music, and 3 channel movies.
Although larger-
For all intents and purposes the room that these will be installed in is 15ftx10ft because of how it's designed/arranged.
Heck, the entire house is something tiny like 1,200 sq feet.
Yes, it's small.
So are my winter heating bills.
post #6 of 10
without a sub I would be looking at towers.
post #7 of 10
I don't have space for towers.
19" Height- Max.
That's allz i gots.
post #8 of 10
19" Height- Max.
That's allz i gots.
Well for that budget, you can get fronts and center - and the bass does go low >>
Some people have preferred the 530, over some more expensive popular speakers
http://www.amazon.com/JBL-Studio-530-Bookshelf-Loudspeakers/dp/B00622STI0/ref=sr_1_2?ie=UTF8&qid=1391736534&sr=8-2&keywords=JBL+Studio+530
http://www.amazon.com/JBL-Studio-520CBK-Channel-Speaker/dp/B00622SUHK/ref=sr_1_1?ie=UTF8&qid=1391736678&sr=8-1&keywords=jbl+studio+520
post #9 of 10
Swan D2.1se, Focal, KEF, Mordaunt Short (kind of hard to find, but I love mine)
post #10 of 10
Lol
Shoot. I'm disappointed. I hoped you meant "Bose" so I could direct you to this new thread: Bose Killers for Every Budget – a Series smile.gif
  Back to Forum: Speakers
