AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Small subwoofer for NYC appartment
post #1 of 20
Hi,
I am upgrading from a HT in a box and have recently bought a pair of Polk TSX550 and Polk FX A4 for the back surround; those are hooked to a Sony STR1040. I am building my HT piece by piece for budget reasons and haven't yet bought my center channel (Polk TSX250 most likely or CSI A4...). I am using this setup for music (a lot), Movies and occasionally games.
I am now looking for a small subwoofer at a reasonable price of course that will:
- match my setup
- keep my wife happy....
- be relatively small
- ensure my neighbors (below, above and on the same floor) don't call the cops.
other relevant information:
- i won't be able to fit a big sub like the BIC F12...the tower speakers are already space consuming
- i have hardwood floor
- the room is 26 feet wide by 12 long and i am roughly 11 feet from the front speakers
- the front speakers are against the external wall and so will the subwoofer
let me know if you need more info in order to help with an eventual recommendation.
Vince
post #2 of 20
"Reasonable price" is a bit vague, but I'll suggest the SVS SB-1000 or PB-1000, either of which is $499, shipped.
post #3 of 20
i was more around 300$... or less :) of course
post #4 of 20
Dayton SUB-1200, available through parts-express.com. It's an inexpensive but well-rated sub.
See also this thread - List of budget subwoofers ($300 and less) - for more ideas.
post #5 of 20
4 x orbit shifters
post #6 of 20
4 x orbit shifters
post #7 of 20
+1 on the Sub-1200 I would get 2 of them...
http://www.parts-express.com/dayton-audio-sub-1200-12-120-watt-powered-subwoofer--300-629
a review...
http://www.hometheatershack.com/forums/speaker-subwoofer-reviews/71766-dayton-audio-sub-1200-subwoofer-review.html
post #8 of 20
this doesn't really solve for my space issue... dayton seems big already... 2 of them (in 2 opposite corners?)
this seems as big as the BIC F12, right?
post #9 of 20
F12
21 x 19 x 22 inches (HxWxD)
Dayton Sub-1200
Dimensions: 16-3/4" H x 16-3/16" W x 17-3/4" D.
The dayton 10"
Dimensions: 14-3/4" H x 14-3/16" W x 15-3/4" D
You can just stack the subs, but if you have room placing them in different locations can smooth out the response. I guess as seeing you are in an apartment 1 would be good. I have never lived in an apartment where I could use a sub without upsetting the neighbors.
post #10 of 20
You're looking for a small, WAF-friendly sub for ~$300, but your room - assuming an 8' ceiling - is ~2,500 cu.ft. in size. If you also want half-decent performance, something's gotta give.
If it's not going to be size, then IMO you should strongly consider bumping the budget to $499 and getting the SVS SB-1000.
It's very compact and offers good performance - see this review for more information - and if you decide you don't like it (or if it doesn't pass WAF), SVS offers free return shipping within 45 days, so the cost of the in-home demo is $0.
post #11 of 20
Hsu STF-1 (or STF-2 if you raise the budget a little) are good small subs.
post #12 of 20
Outlaw M8 or dayton sub800...neither will do that room any justice but they do fit your size requirement.
Compact
Output
Budget
Pick 2!
post #13 of 20
Vinz,
The HSU STF-1 is 300 shipped, and would be a great choice.
post #14 of 20
Op of you want used sub, I seen some small subs on our local cl. Maybe you might also want to consider used sub.
post #15 of 20
You might want to define your size restriction. Do you require "ultra compact" (say 11" cubed max), or "compact"? I recently did a lot of research on subs in the ultra compact range. I was willing to sacrifice output to avoid having a big ugly box in my living room. However, one problem with size is that small size + relatively high output = high $$$ and small size + low $$$ = low output. Some I considered were Sunfire HRS-8, Earthquake Minime, Nile SW8, Pinnacle Subsonic SW-6.5, Sunfire Atmos, Sunfire True EQ 10 Signature, Mirage MM-6 and Sunfire True Super Junior. The only one you'll sniff for $300 (even used) is the Mirage, and that's only rated to 42Hz, not to mention the company has basically been shut down in the U.S. Besides pipe organ and synths, no instrument I know of goes below 28Hz. Only some of the Sunfires on this list (the models that aren't made anymore) approach that range. So forget the lows of HT, although your low volume level requirements make that seem a low priority to you anyway. But you'll probably have to go up to the "compact" size to fit your price.
post #16 of 20
Hi,
- match my setup
Vince
Vince,
I'm selling a vintage Polk Audio subwoofer (PSW120) that I'm certain would be the perfect fit for your situation. It has served me very well in my former apartment and military barracks. The sub is very compact (13"H x 9.5"W x 19"D). I can gladly answer any questions you may have and provide pictures if you're interested.
post #17 of 20
Originally Posted by mrjenk View Post
Vince,
Hi mrjenk,
if you are in NYC and depending on the price you want to sell this, i might consider. if you are not in NYC, sorry not interested ;)
Vince
post #18 of 20
I'm in Baltimore. Selling price is $125.
Bryan
post #19 of 20
Mordaunt Short Aviano 7. Not going to have extension below 30hz, but since you are in an apartment where deep hitting bass could cause problems with neighbors and restricted by the size of the sub, seems like a good option. Fits your budget, too. Let the wife pick the color to make her happy smile.gif
post #20 of 20
Bryan
Sorry, not interested, but thanks anyway
