AVS › AVS Forum › Display Devices › Display Calibration › Any DIY method of checking a meters accuracy?
post #1 of 8
Have a 4 year old OTC-100 that has seen very little use and has never been calibrated.
Is there a way to determine the meters accuracy or lack there of other than sending it in for calibration?
Thank
TL
post #2 of 8
See this thread
post #3 of 8
Thank
TL
Unfortunately without some kind of known reference there is no way to test it. Being that the Sencore OTC-1000/X-Rite Hubble is a colorimeter, each table needs to be checked on the specific type of display.
post #4 of 8
Wow that's quite the thread!
post #5 of 8
I quick gut check might be to measure the color temperature of mid day sunlight. It should be close to 6500K.
post #6 of 8
I think most of us have pondered the "how can I be sure"
question about our meters.
other than getting a reference meter or sending the meter off
I have not read of a DIY method that can tell you.
I suggested a DIY get together here is SoCal but had no takers.
post #7 of 8
IIRC, D65 (which is what you want to check for rather than 6500K, which can range from a green to a magenta tint) was said to be closest to sunlight at midday on a snow-covered winter day. Sunlight most other times of the year is roughly 5400-5500K. Because it isn't a precise reference, I'd hesitate to use it to validate a meter, even as a quick check .
Edited by Rolls-Royce - 2/10/14 at 2:55pm
post #8 of 8
thinking I'd rather look at a luminous yellow tinge on mine than green or magenta,but it's probably different for every tv..Some site says if you stare at the clouds(at the right time) on a sunny day, and then you could try and make the Tvs grayscale/white the same color of the clouds.Supposedly staring at clouds resets the eyes too the right color temperature.Never tried it as I always thought staring into bright light made them less accurate.
